TwinTurbo.NET: Nissan 300ZX forum - Just use a mig for both.. heres some tips.
Subject Just use a mig for both.. heres some tips.
Posted by KongZTT GT28RS MD on January 14, 2011 at 6:05 PM
  This message has been viewed 293 times.
In Reply To to be completely honest i've never done this before. posted by TTFAIRLADYZ32 on January 14, 2011 at 04:32 PM
Message Drill a small hole in one of the two sheets of metal.. use the MIG with a gun "circular" motion to fill the hole that you drilled. Start in the center of the hole drilled (MIG wire should be in touching bottom layer of metal/center of hole)..
Do a quick swirl ( I would use a little higher heat setting than what you'd usually use on whatever thickness since its a quick burst). Viola! spot weld.
Ps. Use a clamp or vise grips or somthing to keep them tightly together before welding.
When buying a welder.. get a good one to start off with (within your needs).. and dont get the harbor freight welder etc..
I just got a Hobart 140 (same as Miller, few small differences).. and its 110v. So I can use it anywhere and is plenty powerful for things I do for around my Z.
_________________________________________________________________________
~~~ Sig starts below ~~~
MySpace for those who have em'
AIM:Shawn300zxTT
-1997 Acura 2.2 CL, 5spd. Daily Driver.. great little car!
